JillPKitten
Apr 03, 2025Follower
R6400 Router login "netgear genie" Password Reset loop bug
1) Netgear needs to provide an easy to find bug report system that does NOT require a recent purchase, stop basing it on warranty, the router has auto-update, but cannot report a bug about it unless ...
Apr 03, 2025Guru - Experienced User
Usually when its in the password reset loop, you're not hitting all the requirements for the new password.
Make sure its 10 characters
1 special character
1 upper case
1 lower case
1 number.
You might have to reset it to get through the process. You did put it correct in that its a decade old. Its considered EOL and not getting any updates
