DVP1007
Apr 26, 2018Tutor
R6400 Router's LAN Speed is operating 100 Mbps Speed
Model: R6400
Firmware: V1.0.1.36_1.0.25
Issue:
The LAN Ports on the Router is operating at 10/100 Speeds and I am not sure why. I have already tried replacing the Cables and they are al...
- Apr 30, 2018
Replaced All cables issue resolved.
schumaku
Apr 27, 2018Guru - Experienced User
With the network links clearly negotiating to Gigabit (you can see this on the port LED, the QTS Web UI, or the Windows network information: Is the R6400 operating in router or in access point mode? There is a known limitation with the access point mode -> R6400 Causing Slow Data Transfer over LAN - because of the GbE ports are handled by the CPU in AP mode, there can't be GbE wire performance. Consider adding a dedicated GbE switch instead of using the R6400 GbE "switch" ports.
- DVP1007Apr 27, 2018Tutor
Hello,
The Router is not used as AP its connected to the Model and used directly as a Router. Yes QTS and all OS shows 1GBe Connection. I am so really stumped I am not sure where to look at. I made the cables myself and direct connection works fine as well between computer and NAS.
