Aandc
Dec 23, 2016Tutor
R6400 set up
Can not get TV or printer to sign into network
- Dec 31, 2016Got completely fed up with this router and returned it. Bought Linksys, set it up in 10 min no problems.
Aandc
Dec 24, 2016Tutor
I have tried both several times . I have tried the printer wireless and connected to the router USB. The TV works sometimes and sometimes it just won't connect either to the regular network or even the guest
Dec 24, 2016Guru - Experienced User
Understood. Were you using WPS or manually entering the configuraton on the printer and TV?
What model printer and TV? Do these devices support 2.4ghz only or both bands?
Is this a new purchase? You could try Netgear support.
