Aandc
Dec 23, 2016Tutor
R6400 set up
Can not get TV or printer to sign into network
- Dec 31, 2016Got completely fed up with this router and returned it. Bought Linksys, set it up in 10 min no problems.
Aandc
Dec 24, 2016Tutor
Not sure Arris tg862 from cable company
- StephenBDec 24, 2016Guru - Experienced User
Aandc wrote:
Not sure Arris tg862 from cable companyThat is 802.11 a/g/n.
Aandc wrote: They all worked on old router just not enough range and too many devices
If you still have the Arris you could try to match the SSID, passphrase and other security settings.
