starro01
Jan 23, 2017Follower
R6400 signal drop off
Hey gang, I'm using the R6400 and am having signal issues where I will get frequent slow downs- enough to cause my requests to time out. Does not seem to matter what I'm doing with it. Even if I'...
- Jan 25, 2017
Hi starro01,
1. What is the firmware version of the router?
2. Have you done a factory reset after updating the firmware? If not, we recommend doing so. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
3. Does the issue persist on the your wired devices as well? If yes, you can try changing the MTU. Check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
4. You can also try changing the channel. It is best to use a WiFi analyzer to check for the best channel available in the area. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23783
Dexter
Community Team
