sb123
Apr 06, 2017Aspirant
R6400 slow internet
I am having extremely slow internet speeds thNetgearhe netgear router I just purchased. the wifi and lan speeds are just crawling. I replaced a 4-year-old router that was running much faster v...
- Apr 13, 2017
Hi sb123,
1. Please check your connection while bypassing the router and connected straight to the modem.
2. What is the firmware version of the router?
3. You can try resetting the router.
4. You can try changing the MTU. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
DexterJB
Apr 13, 2017NETGEAR Moderator
Hi sb123,
Dexter
Community Team
- DexterJBApr 17, 2017NETGEAR Moderator
Hi sb123,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- uzhgorodetsJul 23, 2017Aspirant
slow speed issue, a few weeks ago my router just started slowing download speeds down, i'm supposed to be getting over 100mbps and i do when connect directly to the modem but it slows down to like 5-20mbps when i connect my router, i'm connected via cat 5 wire, my Firmware Version V1.0.1.24_1.0.18, i don't know what the problem is. i have the router for about 16 months now and it have been working great untill a few weeks ago
- cescobarJul 27, 2017Aspirant
Router Model: R6400 AC1750
Firmware: V1.0.1.20_1.0.16
I encountered the same issue after upgrading to the latest firmware. WIFI connection became very very very slow and unreliable. I downgraded to version V1.0.1.20_1.0.16 and it seems to have helped, although the WIFI is still slow compared to before I upgraded to the latest firmware.
I suggest to downgrade and see how that goes. Make sure to reset your router first before downgrading.
