BillyNg
Jan 11, 2018Aspirant
R6400 suddenly stop working with strange LED pattern
Hi guys, I have been using this router for few months, suddenly it stopped working for no reason and the LED pattern is really strange to me. 4 LAN LED and the internet are blinking every second....
- Jan 12, 2018
One thing to check would be the voltage on the power supply if you have a meter. I've not had or seen that problem, but my two immediate thoughts are bad power supply or component failure perhaps because heat. Heat is always an issue, so best to have it in a well ventilated area. Not saying your isn't, just making mention.
BillyNg
Jan 15, 2018Aspirant
Thanks for your inputs. Heat should not be an issue because i placed the router on the table with nothing around it. I will find another power adapter to see if the it is really the root cause.
DexterJB
Jan 17, 2018NETGEAR Moderator
Hi BillyNg,
1. Is your connected device still getting a valid IP address?
2. You may check the link below on how to proceed with TFTP.
http://kb.netgear.com/app/answers/detail/a_id/22688
Dexter
Community Team
