maliciousa
Apr 26, 2016Aspirant
R6400 Teaming Mode
I've got my new ReadyNAS 104 coming in tomorrow (giggity) and I'm planning on bonding the NICs. However, I'm not sure which, if any, teaming modes my R6400 will support. I've searched high and low ...
- Apr 27, 2016
Hi maliciousa,
Port aggregation is not support by the R6400. You may want to look into the R8500 since it supports port aggregation. You can check the link below.
http://netgear.com/home/products/networking/wifi-routers/R8500.aspx
Dexter
Community Team
DexterJB
Apr 27, 2016NETGEAR Moderator
Hi maliciousa,
Dexter
Community Team
- maliciousaApr 28, 2016Aspirant
Thanks for the info. I went and got the R8500, and wow, this thing is a beast. I had some wierd trouble setting the router up initially (probably an issue with my U-Verse Gateway actually), but nothing a router reboot couldn't fix.
I did discover a strange bug while setting up parental controls, is there a way I can let someone at Netgear know about that?
- DexterJBApr 30, 2016NETGEAR Moderator
Hi maliciousa,
I'm glad you got it working. May I know what the issue is with the Parental Controls feature?
Dexter
Community Team
