maliciousa
Apr 26, 2016Aspirant
R6400 Teaming Mode
I've got my new ReadyNAS 104 coming in tomorrow (giggity) and I'm planning on bonding the NICs. However, I'm not sure which, if any, teaming modes my R6400 will support. I've searched high and low ...
- Apr 27, 2016
Hi maliciousa,
Port aggregation is not support by the R6400. You may want to look into the R8500 since it supports port aggregation. You can check the link below.
http://netgear.com/home/products/networking/wifi-routers/R8500.aspx
Dexter
Community Team
maliciousa
Apr 30, 2016Aspirant
Absolutely. When setting the parental controls using the Genie app (on an iMac), I selected custom filtering settings. If I chose to filter out "Typo Squatting", the settings wouldn't save and it told me there was an error saving my settings.
I verified that one setting was the problem by enabling each desired filter one by one, until that problem came up.
- DexterJBMay 01, 2016NETGEAR Moderator
Hi maliciousa,
Please provide a screenshot of the setting and the error message.
Dexter
Community Team
