Olivier21's avatar
Olivier21
Follower
Sep 10, 2017
R6400 trouble connecting printer
MacBook OS Sierra
Printer Brother HL-1430
Neatgear USB Control Center does not show the printer name only Printer - - and is able to connect. After connecting is states 'Mannually connected to MacBook'. Nevertheless the printer is offline, so the router does not activate the printer. After manually activating the printer it still states the printer is offline.
The Firewall is off, the printer USB cable is working correct what cann it be more?
  • Hi Olivier21,
    1. Please try removing and adding the printer on your Mac.
    2. If the issue persists, please try uninstalling and re-installing the USB Control Center.
    3. Does the issue persist on your other computers?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Olivier21,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Olivier21,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
