22gotboost
Oct 26, 2021Tutor
R6400 Unable to Access Routerlogin.net or anyway to manage router settings
I cannot access any of the avenues to manage router settings. I have tried a PC and the Night hawk App as well as router IP. Nothing gets me access.
- Oct 26, 2021
Fixed.
Oct 26, 2021Guru - Experienced User
What error are you getting?
what modem/gateway is the router connected to?
Have you tried the routers IP address? if so, what ip address?
22gotboost
Oct 26, 2021Tutor
The router is connected to a ET2251 cable modem. I am not getting any error messages; just a login screen loop.
- plemansOct 26, 2021Guru - Experienced User
What login screen loop?
The netgear one?
Got a screen snip?
Have you tried a different computer and/or web browser?
- 22gotboostOct 26, 2021Tutor
www.routerlogin.com and the IP address. I have tried the app via a smartphone. I type in the ADMIN in the login and PASSWORD in the password. And it goes right back to the initial screen.
Fixed.
