Mph3842
Nov 19, 2021Aspirant
R6400 used as a switch, not as a router
I just got T- Mobile 5g internet and I am using the wifi signal from it. I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via...
michaelkenward
Nov 20, 2021Guru - Experienced User
Mph3842 wrote:
I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router.
You could turn the R6400 into a wireless access point. Then just turn the wifi off with the switch on the top.
Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a network drive?
I see no sign that AP mode disables ReadySHARE.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But you'll have to try it.
Is this related to the issue you asked about six months ago?
I have an R6400 and want to connect a HDD via USB ... - NETGEAR Communities
PS There really was no need to waste anyone'e time by going to a different section to deal with this issue. The question is generic and the answer would be the same for the Nighthawk section as it is for this one.
- Mph3842Jan 28, 2022Aspirant
Yes it is the same issue. I tried the AP setting and it did not work. Thanks for your help.
michaelkenward wrote:
Mph3842 wrote:
I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router.You could turn the R6400 into a wireless access point. Then just turn the wifi off with the switch on the top.
Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a network drive?I see no sign that AP mode disables ReadySHARE.
