Mph3842
Nov 19, 2021Aspirant
R6400 used as a switch, not as a router
I just got T- Mobile 5g internet and I am using the wifi signal from it. I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via...
michaelkenward
Nov 20, 2021Guru - Experienced User
Mph3842 wrote:
I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router.
You could turn the R6400 into a wireless access point. Then just turn the wifi off with the switch on the top.
Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a network drive?
I see no sign that AP mode disables ReadySHARE.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But you'll have to try it.
Is this related to the issue you asked about six months ago?
I have an R6400 and want to connect a HDD via USB ... - NETGEAR Communities
PS There really was no need to waste anyone'e time by going to a different section to deal with this issue. The question is generic and the answer would be the same for the Nighthawk section as it is for this one.
Mph3842
Jan 28, 2022Aspirant
Yes it is the same issue. I tried the AP setting and it did not work. Thanks for your help.
michaelkenward wrote:
Mph3842 wrote:
I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router.You could turn the R6400 into a wireless access point. Then just turn the wifi off with the switch on the top.
Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a network drive?I see no sign that AP mode disables ReadySHARE.
