PabloPicasso
May 12, 2018Tutor
R6400 V2 dropping internet after longer lack of activity
Hi!
I have 6400v2 with V1.0.2.52_1.0.39 firmware. (which was upgraded during my usage). But since the beginning I have a problem with the device, mainly it's turning off the internet after lon...
- Sep 30, 2018
Hi all,
hint for others, as suggested by michaelkenward, resetting to factory defaults after firmware upgrade solved the problem.
Thanks all!
PabloPicasso
May 13, 2018Tutor
Hi!
Leds look normaly, wifi leds are blinking as normal. I haven't tried reset to factory defaults.
michaelkenward
May 14, 2018Guru - Experienced User
Can other devices connect to the wifi during this alleged dead periods?
If the LEDs look right when the internet appears to be "down", maybe the problem is at the receiving end, the computer.
Check that your PC does not have Windows (?) settings that send devices to sleep.
- PabloPicassoMay 14, 2018Tutor
Hi!
thanks for answering. No they cannot, all devices have same problem. I've checked with 2 smartphones and 3 laptops.
- DexterJBMay 22, 2018NETGEAR Moderator
Hi PabloPicasso,
As suggested by michaelkenward, a factory reset is recommended after a firmware update. That's something you can try.
Dexter
Community Team
