utmba95
Sep 22, 2020Aspirant
R6400 WIFI requires almost daily reboots with 1.0.1.50, .52, 62
Due to the security issues in 1.0.1.46 and earlier, I tried to use the latest FW. However, on an almost daily basis one of the WIFI SSIDs would not pass traffic. The 5G would often disappear, and t...
wcalifas
Sep 22, 2020Prodigy
You should revert back to a previous firmware and see if that fixes it. You can manually find the previous firmware in the netgear.com website under "support" where you type your router's model number and it will let you download the firmware manually. Once you do that update with your laptop hardwired to the router and apply the older firmware by logging into your router through your browser. I would use microsoft edge browser over the other browsers to apply the firmware.
- utmba95Sep 22, 2020Aspirant
I wasn't completely clear,but I did go back to 1.0.1.46 23 days ago, and I've had no problems since. However, I'd like a version that works and also has the recent security fixes. We'll see if others have the same problem.
- olympos1625Nov 12, 2020NETGEAR Employee Retired
Hi utmba95,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Upon checking from our system, we don't see any similar issues about the latest firmware. Please update the firmware of the router then reset the router afterward and observe the connection if it exhibits the same issue as before.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
