TaterSalid
Aug 26, 2018Virtuoso
R6400 Will Not Boot
So the Wife and I have started exploring thrift/antique stores. While she dug through hosuewares I went to the electronics section. I found an R6400 that appeared almost new. I powered the unit. It b...
- Aug 29, 2018
I may come back to this later. For now, I quit. The purpose of this router was to set up a VPN gateway. I have ordered a WNR3500Lv2.
I have had a 3500Lv1 in service for 9 years with great results. The v1 will be repurposed for for VPN using DDWRT firmware.
Thanks for the help.
michaelkenward
Aug 27, 2018Guru - Experienced User
TaterSalid wrote:
I held the reset button to default the unit to factory. This went well. A little later the power light went amber. I'll deal with this tomorrow!
There is the more "severe" reset procedure:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
I would also investigate the possibility that the power supply is defective in some way. Look for something with the same volts and (+/-) polarity and enough amps.
TaterSalid
Aug 27, 2018Virtuoso
Michael,
I have tried the reset several times as suggested. I also tried a 1A power supply. 1A should power this thing static and does without getting hot. The result was the same.
- antinodeAug 27, 2018Guru
> [...] Is the ability to PING required for TFTP to work?
"ping" is a very low-level communication test. If it fails, then I
wouldn't expect much else to work, including TFTP.
If the normal restart and/or reset operations leave the gizmo in some
abnormal/confused state, and I were desperate, then I might try the
TFTP command at different stages in the start-up procedure, in the
(dim?) hope of catching it in a receptive state.
I know nothing, but I've read of people who claim to connect to an
internal serial port, which may allow some access to a more-than-usually
crippled device. A Web search may find examples.
