PhilPhilbert
Jan 14, 2018Follower
R6400 wired connection drops out briefly every half hour or so (wireless never does)
Hello all. This is regarding my R6400 WiFi Router with the most recent firmware (V1.0.1.34_1.0.24). For a long time now my ethernet cable connection from Router to desktop PC (windows 10 64) has dis...
- Jan 17, 2018
Hi PhilPhilbert,
1. Have you tried all the other LAN ports on the router?
2. Have you tried using another Ethernet cable?
3. Have you tried resetting the router to factory default?
4. Does the issue persist with your other wired devices?
5. Does the issue persist when you bypass the router and connect straight to the modem?
Dexter
Community Team
DexterJB
Jan 25, 2018NETGEAR Moderator
Hi PhilPhilbert,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
