afterglow727
Jan 12, 2023Aspirant
[R6400] Wired Works, Wireless drops out frequently during day
I've got an R6400 handling wired and wireless networking in my small apartment. Always once a day, sometimes twice a day, all wireless devices will lose wireless internet connectivity, and I will...
chamanea
Jul 27, 2025Aspirant
Hi, having the same issue with my R6400 V2, did you end-up finding a solution to your wifi disconnection issue ?
afterglow727
Jul 28, 2025Aspirant
I somewhat found a solution.
I found there were a lot of wireless networks in my area (using some free wifi-detecting apps), so I manually set my wireless channel to one with the least interference from nearby networks.
This helped substantially -- I would go maybe 2 or 3 weeks without needing to reboot my router.
Not perfect, but a big help.
I've since moved to an area with much less interference, and have not had to reboot it at all.
I'm not sure why rebooting would be the solution to interference -- but it seemed like general interference was the culprit.
