Sanjeev_173
Mar 17, 2020Aspirant
R6400 Wireless diconnection.
Model R6400 AC1750 Smart WiFi Router Wireless connection drops at regular intervals for 5 seconds or more. Updates are upto date.
- Mar 19, 2020
I consistently have the same issue, and usually after a firmware update. I am currently on Firmware Version
V1.0.1.52_1.0.36I factory reset my router, updated to latest firmware after reading other articles in KB.
My ethernet is consistently 150mbps but my wifi will drop to 3mbps and occasionally bounce to 150mbps+. Its very inconsistent and I have hardwired most of my streaming devices because of this.
I ahve not seen any help from Netgear in these threads and it is definitely the roter or firmware. We recently replaced Netgear at the offcie for the same reason - and rchanged brands. The lack of response and accountability is terrible.
Mar 18, 2020Guru - Experienced User
There's 2 versions of the R6400. which version do you have?
What firmware is currently on it?
what modem is it connected to?
does the wireless fully disconnect or does it say "connected but no internet available"?
- Sanjeev_173Mar 20, 2020AspirantAC1750
Model R6400
Firmware V1.0.1.52_1.0.36
Modem Xfinity
Cable and wireless drops for few seconds and comes back on. If you or on call it gets disconnected. Watching movies..pauses.
Thank you- plemansMar 21, 2020Guru - Experienced User
Sanjeev_173 wrote:
AC1750
Model R6400
Modem Xfinity-----which one? some have an integrated router that could be causing the issue?
Thank you
