Sanjeev_173
Mar 17, 2020Aspirant
R6400 Wireless diconnection.
Model R6400 AC1750 Smart WiFi Router Wireless connection drops at regular intervals for 5 seconds or more. Updates are upto date.
- Mar 19, 2020
I consistently have the same issue, and usually after a firmware update. I am currently on Firmware Version
V1.0.1.52_1.0.36I factory reset my router, updated to latest firmware after reading other articles in KB.
My ethernet is consistently 150mbps but my wifi will drop to 3mbps and occasionally bounce to 150mbps+. Its very inconsistent and I have hardwired most of my streaming devices because of this.
I ahve not seen any help from Netgear in these threads and it is definitely the roter or firmware. We recently replaced Netgear at the offcie for the same reason - and rchanged brands. The lack of response and accountability is terrible.
Pstivthnkn
Mar 19, 2020Tutor
V1.0.1.52_1.0.36
- plemansMar 20, 2020Guru - Experienced User
What modem are you using?
sometimes firmware is corrupt. have you tried re-installing the firmware and resetting again? a reset only removes settings so if it was corrupt, it needs a reinstall.
and if that doesn't work, try downgrading a version of the firmware.
- Sanjeev_173Mar 20, 2020AspirantRe:AC1750 Smart WiFi
Model R6400
Modem is Xfinity.
Firmware V1.0.1.52_1.0.36
I will try resetting.
Thank you.
