momaro20
Sep 02, 2016Follower
r6400 wireless off
For some reason my wireless stopped working and I can't figure out why. I've looked through the forum and tried some of the suggestions but nothing is working.
When I login to the router and get to the genie, the home page shows that "wireless is off". When I click on that button to check settings, it show that "Enable Wireless Router Radio" is not checked on both the 2.4 and 5 ghz devices. I tried checking them on...it thinks for quite a while and then comes back to the same screen with neither of the radio check marks checked again.
I rebooted.
I turned router on and off again.
I reset.
What else should I do?
- Retired_MemberSep 02, 2016
Push the button on top right front again and or read manual, if you cannot get it to work preform a reset to factory defaults
- Retired_Member
See page 11 of manual for the wifi switch.
NETGEAR AC1750 Smart WiFi Router Model R6400 User Manual.pdf
