vinhop's avatar
vinhop
R6400 with ATT wireless modem for PS4
I cannot get a NAT Type 2 on my router.  I have set a Static IP, I think, by doing an Address Reservation.  I reserved xxx.xxx.xx.15, which is the PS4 IP address.  I then opened the ports specified b...
  • antinode's avatar
    antinode
    Apr 04, 2018
    > [...] The ATT modem/router lists the make/model as Z700A. [...]
       Ok.  If you're using its telephone features, then you probably want
    to leave it as-is, and configure the R6400 as a WAP.
    > Before I do the WAP set up, the PS4 is connected to the router by an
    > ethernet cable, if that makes a difference.
       Shouldn't matter.  It's normally called a "wireless access point",
    but it acts like a network switch with wireless capability.  Devices
    which are connected to the (LAN) Ethernet ports on the R6400-as-WAP
    should be part of the (newly extended) LAN, just like any wireless
    client devices which might connect to it.
       When you Enable AP Mode on the R6400, it should ask you how it should
    get its new LAN IP address.  You need to know its LAN IP address if you
    ever want to talk to its web site again (without having to search for
    it).
       My usual advice is to shrink the DHCP pool on the main router (if
    necessary), and assign a static, non-pool IP address to the access point
    ("Use fixed IP Address (not recommended)."), so that it's easy to find
    the WAP.  For example, DHCP pool: ".2" - ".199", WAP IP address: ".200"
    or ".250".  (Something memorable, outside the pool.)
       My quick Web search for Z700A found a User Guide which showed a DHCP
    pool of ".10" - ".99", which should be ok as-is.  (Netgear routers tend
    to default to ".2" - ".254", which leaves nothing free.)
    https://www.att.com/ecms/dam/att/devicesupport/3000-3999/3030/ATT-Home-Base-Z700a.pdf
       The alternative, "Get [its LAN IP address] dynamically from existing
    router.", would work as well, if there were a way to reserve an address
    for the R6400-as-WAP on the main router.  I didn't see a way to do that
    in the Z700A User Guide.
