Holymoly
Feb 26, 2016Aspirant
R6400 Won't broadcast SSID all of a sudden, can't manually type either
Hi all, Left for work this morning and came home to no wifi. We have internet fine and all the lights are white on the router but no wifi. Now I don't know much about this stuff but I know i...
netwrks
Feb 26, 2016Master
Did you reset your router to factory default, after the firmware update? If you didn't, you should..
Holymoly
Thanks, I just did. Nothing.
Matter of fact, I'm getting no lights at all on the 2.4 and 5 ghz buttons. The power button, the next one, and the ethernet port 1 (hardwire) is the only thing lit white. Everything else is out still.
- TheEtherFeb 26, 2016Guru
There is a physical button on the router to toggle the Wi-Fi radios. You may have inadvertently pushed it. Push it for 2 seconds. See page 11 in the manual (link).
- HolymolyFeb 26, 2016Aspirant
Unbelievable by the way. I did hit them earlier and nothing happened but this time it worked fine. Thanks all.
