kohak
Mar 13, 2019Aspirant
R6400
when trying to acess modem config after reset ....page says must connect to wifi to be able to?
- Mar 15, 2019
I had tried all solutions you mentioned as I had done extensive research on internet.. In the end as I said the only thing that would work was only connect thru wifi with a naked router. Couldn't use ethernet connection to naked router....I try to run a secure setup so my default browser was highly configured that was why I tried browsers that I don't use... to no avail....in the end it was my default browser that connected to gui just with out internet/modem connected. Probably no one else well have identical problem but our discussion may help someone hopefully.
antinode
Mar 15, 2019Guru
> [...] but it would give that error with using 192.168.1.1.... [...]
That sounds (to me) like a web browser cache problem. If you thrash
around with multiple browsers, different URLs (name, address), and I
don't know what else, then it can be easy to get lost.
For a true test, start with a clean browser, connect the router to
only one computer (not to the Internet), and see what happens. Ideally,
that one computer should be set to use DHCP for everything, including
the DNS server.
If you complicate the system (different DNS server, Internet
connection, too-clever browser, ...), then whole new vistas of potential
problems open up before you.
kohak
Mar 15, 2019Aspirant
