Strongwolf's avatar
Strongwolf
R6400
Hi. I'm new around here. Got a question; can I use the USB port on the back of the router as an internet input?
  • > R6400
       R6400[v1] or R6400v2?  Firmware version?
    > [...] can I use the USB port on the back of the router as an internet
    > input?
       No.  Visit http://netgear.com/support , put in your model number, and
    look for Documentation.  Get the User Manual.  Read.  Look for "USB".  I
    see "Storage Devices" and "Printer".
       What would you like to connect to the R6400[vX] USB port to act as an
    Internet connection?  (Which would be bidirectional, so not really an
    "input".)
  • > R6400
    > input?
    "input".)
    • Strongwolf's avatar
      Strongwolf
      Sorry, but I didn't explain myself. I have four (4) pcs connected by a 4 ports HDMI KVM. I'm really using the R6400 as a switch so all the pcs have internet connection. What I really want to do is to provide an internet access throu an USB port that the KVM has but I don't have the specificacions of the KVM (bought it @ Ebay)). I know this is beyond this community scope. Sorry again.
      • antinode's avatar
        antinode
        Guru
        > [...] I have four (4) pcs connected by a 4 ports HDMI KVM. I'm really
           That's fine.  You can connect multiple computers to the Internet at
        the same time, using an R6400 (as a NAT router).  That should work
        regardless of how many keyboards/mice/displays you have connected to any
        of them.  Nothing to do with a KVM switch.
        > [...] What I really want to do is to provide an internet access throu
        > an USB port that the KVM has [...]
           I don't understand that.  What does "Internet access" have to do with
        a KVM switch?  Normally, as I understand a KVM switch, the USB ports are
        used for keyboards and mice (and, perhaps, other USB-connected gizmos).
        That's all entirely independent of any Ethernet/wireless/Internet
        connections to any computers.
        > [...] but I don't have the specificacions of the KVM (bought it @
        > Ebay)).
           Even gizmos bought on Ebay can have a maker and model number.  This
        new Inter-web thing can often be used to find detailed information on
        various devices, but a better description than "the KVM I bought on
        Ebay" may be needed to find it.
        > Sorry again.
           Apology not needed, only a better description of the actual problem
        which you are trying to solve, and what your equipment is.
