RobertSearl
Jul 04, 2021Aspirant
r6400
I installed the latest update: Firmware Version V1.0.1.72_1.0.45 Now I get messages like: "This site can’t be reached Check if there is a typo in login.gmx.com. If spelling is correct, try ...
Jul 04, 2021Guru - Experienced User
What gateway/modem are you connected to?
did you try a factory reset after the update? I'd try this before downgrading
Did you try a different dns server? like googles at 8.8.8.8 or 8.8.4.4 or even cloudfare at 1.1.1.1
- RobertSearlJul 12, 2021Aspirant
I did a reset, no joy.
