RobertSearl
Jul 04, 2021Aspirant
r6400
I installed the latest update: Firmware Version V1.0.1.72_1.0.45 Now I get messages like: "This site can’t be reached Check if there is a typo in login.gmx.com. If spelling is correct, try ...
atekkof
Jul 11, 2021Aspirant
Hello, I am writing to confirm that I am also having the same issue. I spent an entire week troubleshooting my DNS before finding this thread. Definitely the Netgear firmware and I'm using the R6400. It typically takes half a year between firmware versions, so I really hope someone in their dev department in paying attention.
Setting the DNS locally on the devices should help in the short term, but I have a lot of devices and I want them all to use the same DNS servers, so this is super annoying.
And yes, I second that it only seems to be Windows devices at this point.
