RobertSearl
Jul 04, 2021Aspirant
r6400
I installed the latest update: Firmware Version V1.0.1.72_1.0.45 Now I get messages like: "This site can’t be reached Check if there is a typo in login.gmx.com. If spelling is correct, try ...
RobertSearl
Jul 12, 2021Aspirant
I am having the problem as you state. Probem is; I have no idea about DHCP or DNS settings. I have NEVER had a router problem until this last Netgear "update". If I could go back in time, I would.
Thanks for your help!
Jul 12, 2021Guru - Experienced User
RobertSearl wrote:. If I could go back in time, I would.
You can downgrade. Simply go to the support site for your device, click on downloads, and then "view previous versions".
Once downloaded, extract it, and follow the manual firmware update process but use the downgraded version of the firmware and not newer.
Anytime you downgrade, I'd recommend doing it over a hardwired connection.
- RobertSearlJul 12, 2021Aspirant
I could not find "view previous versions" for the R6400.
- plemansJul 12, 2021Guru - Experienced User
Just looked it up.
you clicked on downloaded?
then scroll down to the bottom.
you'll see "+view previous versions"
I'd screen shot it for you but not on a device to do so right now
