avdavis58
Nov 10, 2021Aspirant
R6400
I changed out my modem and have a default gateway address (my IP address changed) how do I configure a Port Forwarding or is there another way
Nov 10, 2021Guru - Experienced User
What modem/gateway do you have?
Have you looked through the manual on port forwarding?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
michaelkenward
Nov 11, 2021Guru - Experienced User
And what do you really want to achieve?
I can't tell from your message. People often talk about "Port Forwarding" when they really need to do something else.
- avdavis58Nov 11, 2021AspirantI am trying to log into a server to get the IP address but lost the password, what can I do?
- plemansNov 11, 2021Guru - Experienced User
You've lost the password for the router?
Have you tried the password recovery option?
If you don't know the answers to those (or didn't set them up), then you'd need to factory reset to get back in.
- michaelkenwardNov 11, 2021Guru - Experienced User
avdavis58 wrote:
I am trying to log into a server to get the IP address but lost the password, what can I do?Which IP address? The local one for your router on your network? The one that your ISP gives you on the Internet?
Your first message referred to "a default gateway address". That could mean many things. That's why I asked what you are trying to do.
As well as the advice from plemans, this might be useful.
If you cannot login to your router | Answer | NETGEAR Support
