stargazer01
Jan 22, 2017Aspirant
R6400/AC1750 randomly disconnecting
I just got my new router last night and immediately started having problems. First, I was attempting to migrate my chromecast devices over to the network and each time I tried to reset the chrome...
- Mar 05, 2017
Hi stargazer01,
You can try changing the wireless channel and/or the mode for the 5GHz band on the router and see if the issue persists.
Dexter
Community Team
DexterJB
Jan 23, 2017NETGEAR Moderator
Hi stargazer01,
1. Does the issue persist on both wired and wireless?
2. Please try resetting the router.
3. If the issue persists, try re-flashing the firmware then reset and reconfigure the router.
Dexter
Community Team
stargazer01
Jan 24, 2017Aspirant
01. I cannot directly wire any computer in my house bc they all lack ethernet ports. I do know the router goes through an entire power cycle at least once, and often twice. The modem was previously connected to Apple's Airport and there was never such a problem
02. This was the firt thing I tried.
03. I tried this last night and it seemed to fix the issue as I was connected most the day. Didn't want to go back to the immediate last version (101-12) because I learned about some security scare dated November or December. Flashed -18 again. I re-introduced all my devices. Seemed good until I was watching videos later in the evening. Then it re-started itself. Had to wait 5 mins as it went through three different cycles.
Searching around I've noticed this router allows me to flash third party firmware. Might this prove a solution? Or might I flash back to a previous firmware without exposing myself to the security problem?
- DexterJBJan 25, 2017NETGEAR Moderator
Hi stargazer01,
We highly recommend having a wired connection when flashing the firmware to make sure that the connection will be stable. You can also try changing the wireless channel. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23783
Dexter
Community Team
- stargazer01Jan 25, 2017Aspirant
ok DexterJB , I'll try again if I can find a computer to borrow with ethernet.
I've changed the channels anyways. Seems not to have made a difference.
I did realize I had the ability to answer one of your previous questions: I have a smartthings hub connected to the router and it loses connection every time the router reboots. It seems the router needs to at least ccle three times before coming fully online again.
Does the new information about the problem with the wired affect your diagnosis?
- DexterJBJan 26, 2017NETGEAR Moderator
Hi stargazer01,
1. Are you saying that the router reboots on its own?
2. Yes, because it might be an issue with the MTU value if the wired connection is affected or possibly a simple cable issue.
Dexter
Community Team
