stargazer01
Jan 22, 2017Aspirant
R6400/AC1750 randomly disconnecting
I just got my new router last night and immediately started having problems. First, I was attempting to migrate my chromecast devices over to the network and each time I tried to reset the chrome...
- Mar 05, 2017
Hi stargazer01,
You can try changing the wireless channel and/or the mode for the 5GHz band on the router and see if the issue persists.
Dexter
Community Team
stargazer01
Mar 02, 2017Aspirant
I think it's out of warantee.
Though, I have found some interesting things.
I just disabled the 2.5G band for a while and used a separate router to do it's work. All the heavy lifting on the netgear: chromecast speakers, chromecast and the laptops. The router never crashed. Having flashed netgear firmware several times, I decided to try one of the open source ones to see if I could regain full function of both (or three?) radios. Success! I have devices across both radios and nothing bad happens. Importantly (to me), my laptop is hanging out on the 2.5 band and it's not crashing like before! On tomato the router stops making the screaming noises when the demands on the network shifted (e.g., when I started streaming) like it did on the oem firmware too... huh...
But then I switch to the 5Ghz band. Crash! Immediately. Rather than being stuck in a boot loop, it attempts to re-boot like before and then, failing, literally powers itself off. I can power it back on no problem and the rest of the devices work on the network fine. Laptop & evertthing works fine on 2.5, then I switch to 5 and predictably it crashes again.
So I'm thinking it's been the laptop all along... or something about it stressing the router. Other laptops aren't doing it. It's a microsoft surface pro 4, all drivers up to date
Would you have any idea what's possibly going wrong here? Settings I may be able to tinker with on the router and/or the laptop?
DexterJB
Mar 05, 2017NETGEAR Moderator
Hi stargazer01,
Dexter
Community Team
