ITmouse
Jul 11, 2022Aspirant
R6400v2 — AC1750 Smart WiFi - Can't Connect to Work
A couple of weeks ago I switched ISP and also got a new wireless router. The previous router was supplied by AT&T. Internet works great with the new router and ISP. Biggest issue, I cannot remote ...
Jul 11, 2022Guru - Experienced User
What current modem/gateway do you have the R6400 connected to?
- ITmouseJul 11, 2022Aspirant
The ISP supply the media converter from fiber to cat5 connector. (Don't know the device name or model. Will have to check that when I get home from work). The R6400 is the router and wifi. I cannot remember the gateway settings, since I use the netgear auto internet setup and it use the dhcp settings from the ISP.
