ITmouse
Jul 11, 2022Aspirant
R6400v2 — AC1750 Smart WiFi - Can't Connect to Work
A couple of weeks ago I switched ISP and also got a new wireless router. The previous router was supplied by AT&T. Internet works great with the new router and ISP. Biggest issue, I cannot remote ...
Jul 11, 2022Guru - Experienced User
What current modem/gateway do you have the R6400 connected to?
ITmouse
The ISP supply the media converter from fiber to cat5 connector. (Don't know the device name or model. Will have to check that when I get home from work). The R6400 is the router and wifi. I cannot remember the gateway settings, since I use the netgear auto internet setup and it use the dhcp settings from the ISP.
