Arius
May 15, 2022Aspirant
R6400v2 - 1.0.4.122_10.0.95 Firmware Upg Adds dnsmasq V2.78 ?
My R6400v2 router is currently running firmware v1.0.2.56 When logged into it it has a message that a new firmware upgrade is available. Current GUI Language Version: 1.0.2.56_2.1.38.1 New...
- May 23, 2022
Since I am converting my router to DD-WRT and it has dnsmasq fully supported this is no longer an issue.
May 16, 2022Guru - Experienced User
Pretty sure its just whats built in for its own dns resolver/configuration.
Other than the small amount of front end changes you can see in the gui, there's not much to change.
- AriusMay 16, 2022Aspirant
I'm still not convinced. Why would Netgear be using dnsmasq code that was developed to replace DHCP and name service when they have been using code (like other vendors) that predated dnsmasq?
- AriusMay 23, 2022Aspirant
