noether's avatar
noether
Tutor
Sep 03, 2020
R6400v2 2.4ghz network crawling, but 5ghz network fine
In the past week or so, my 2.4 ghz network has been unusable. Many devices are suddenly unable to even connect to the network. Others can connect to the network, but not the internet, and others can ...
  • wcalifas's avatar
    Sep 05, 2020
    Could be the recent firmware update, I would try to revert to the one before. You have to go to support on the netgear site and type the model number of your router and then apply the firmware manually
