noether
Sep 03, 2020Tutor
R6400v2 2.4ghz network crawling, but 5ghz network fine
In the past week or so, my 2.4 ghz network has been unusable. Many devices are suddenly unable to even connect to the network. Others can connect to the network, but not the internet, and others can ...
- Sep 05, 2020
Could be the recent firmware update, I would try to revert to the one before. You have to go to support on the netgear site and type the model number of your router and then apply the firmware manually
noether
Sep 06, 2020Tutor
Thank you! It was indeed the firmware. I did revert to an earlier version and the problem is no longer happening.
antinode
Sep 06, 2020Guru
> [...] I did revert to an earlier version and the problem is no longer
> happening.
Revealing the working and failing firmware versions might increase
the value of this report to some future reader. Just a thought.
- noetherSep 08, 2020Tutor
The problem was present while version 1.0.4.98 was installed, and stopped after reverting to version 1.0.4.84.
