Outis
Oct 11, 2022Tutor
R6400v2 200mbps speed cap on latest firmware 104 128 last august
So i don't know what the last firmware to roll back to that wont cuck me im so sick of this 2021 September update had the dns error bug and the 200 speed cap never has been addressed **bleep**ty firm...
Oct 11, 2022Guru - Experienced User
After the update, did you do a factory reset?
Do that. And then during the install, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
(don't install from a backup)
- OutisOct 11, 2022Tutor
yeah did and thought i turned off a lot of those if not all of them but must not have hit apply
yeah wen back to last December same thing idk which update did it buying an asus or tp link router asap done with netgear thanks for respond and for trying i appreciate it
- plemansOct 11, 2022Guru - Experienced User
I've had good luck with tp-link devices.
Never messed with Asus but I've heard good things.
Hope your next device does well for you!
