BobBaniak
Oct 03, 2021Tutor
R6400v2 AC1750 - firmware v1.0.4.118 and v1.0.4.120 is not suitable for use
The last two software updates (v1.0.4.118 and v1.0.4.120) for R6400V2 are one great tragedy. Problems with opening pages, a problem with downloading several files at the same time. The only solution...
Oct 03, 2021Guru - Experienced User
Thanks for posting!
you're not the only one with issues on the latest firmware and the more people that post, the more likely the mods/engineers will see it.
