BobBaniak
Oct 03, 2021Tutor
R6400v2 AC1750 - firmware v1.0.4.118 and v1.0.4.120 is not suitable for use
The last two software updates (v1.0.4.118 and v1.0.4.120) for R6400V2 are one great tragedy. Problems with opening pages, a problem with downloading several files at the same time. The only solution...
RTog
Oct 28, 2021Tutor
Thank you for your post. Our two computers started having trouble opening pages recently. Since it happened on two different computers, I suspected the router. Our router has the firmware V1.0.4.120_10.0.91. Additionally, router admin software "Attached Devices" no longer works although the "Access Control" under the "Advanced" tab will show connected devices.
