BobBaniak
Oct 03, 2021Tutor
R6400v2 AC1750 - firmware v1.0.4.118 and v1.0.4.120 is not suitable for use
The last two software updates (v1.0.4.118 and v1.0.4.120) for R6400V2 are one great tragedy. Problems with opening pages, a problem with downloading several files at the same time. The only solution...
BobBaniak
Oct 28, 2021Tutor
In my case, it was very important that after returning to firmware v1.0.4.106 I did a factory reset. Without a reset the router performed better than on the latest firmware but still not as it should be.
BTW factory reset with firmware v1.0.4.118 or v1.0.4.120 does not help.
