BobBaniak
Oct 03, 2021Tutor
R6400v2 AC1750 - firmware v1.0.4.118 and v1.0.4.120 is not suitable for use
The last two software updates (v1.0.4.118 and v1.0.4.120) for R6400V2 are one great tragedy. Problems with opening pages, a problem with downloading several files at the same time. The only solution...
eyelessmd
Nov 24, 2021Aspirant
Same here with R6400v2 on V1.0.4.120_10.0.91
Every time I'm trying to open wesite I'm getting error that website is unavailable.
Started after I updated from R6400v2-V1.0.4.106_10.0.80
This is unaccaptable and must be fixed ASAP, but at this point, I think that netgear dev team just useless and can't fix it, since this error is present for the 2nd firmware version in a row.
I will appreceate any good router recommendation for smart home with 50+ devices.
