rg51
Mar 16, 2020Tutor
R6400v2 AC1750 with N300extender speed issues
Complained to Comcast about speed issues. Comcast replaced their modem to increase speed to 600mps. Comcast wifi from their modem shows up to 300 mps but limited range . My Netgear router has anywher...
- Mar 17, 2020
rg51 wrote:I do not have any wifi test equipment.----it doesn't take special equipment. A phone for wireless and a pc/laptop/mac for hardwired testing. you can use speedtest app or speedtest.com for hardwired.
The Comcast modem is their newest and suppossed to be for 600mps which I measured on my phone next to it as actually between 300 and 400.-----phones are an indicator but not perfect. its why you want to test over hardwired. I do not know how to measure the hardwired speed into my router or into their modem.-----connect to them, then test using the speedtest app or site.
one thing to keep in mind. 2.4ghz is significanly slower than 5ghz. and then the 2.4ghz speed is reduced going through an extender. 20-40mbps isn't an unexpected speed out of an EX2700 because its an older 2.4ghz based device.
rg51
Mar 16, 2020Tutor
Cannot answer most of your questions as the hardware and install was done by Comcast. All speed tests were done using the xfinity diagnostic on line support tool. Used an iphone10 , a Samsung 8 and an Acer laptop. The extender is an WN 3000RP v3. Installed 2018
Mar 17, 2020Guru - Experienced User
Not trying to be snide but I can't help you with minimal info. the questions I asked can be answered with a little bit of looking at labels and actual testing/research.
Its tough to tell you whats going on with incomplete information.
- rg51Mar 17, 2020Tutor
I do not have any wifi test equipment. The Comcast modem is their newest and suppossed to be for 600mps which I measured on my phone next to it as actually between 300 and 400. I do not know how to measure the hardwired speed into my router or into their modem.
- plemansMar 17, 2020Guru - Experienced User
thanks for all your time!
