liquid64
Jan 17, 2022Aspirant
R6400v2 and ReadyCLOUD issues
Hi everyone. I am having an issue getting my USB thumb drive to show up in ReadyCLOUD. It shows up and works just fine with ReadySHARE (the CIFS/SMB share and HTTP/S protocol), however getting it t...
- Jan 17, 2022
I decided to go ahead and try factory resetting the router, and that did the trick. I can now access the drive via ReadyCLOUD. I've have the router for years and have never reset it, so I guess it was time to.
michaelkenward
Jan 18, 2022Guru - Experienced User
Did you check for new firmware while you were at it. A router that has been left alone for a while might be out of date.
liquid64
Jan 18, 2022Aspirant
Thanks for the reply. Yes, I was running the latest firmware 1.0.4.122.
