MitchGarvis's avatar
MitchGarvis
R6400v2 Attached Devices
I run a lab environment at home that includes several virtual machines. Those virtual machines are not listed in the list of Attached Devices - I suspect because while each has its own virtual NIC, they are all routed through my laptop's wireless NIC, meaning they would all share the same MAC Address. Is there a way to show which devices are connected (Both physical and virtual)? Thank you in advance!
    • MitchGarvis's avatar
      MitchGarvis
      You know what? I can't believe I didn't look at that. It looks like there is no way around it on client-side Hyper-V, but I can live with that. If that's the answer, then so be it 😉
      Thanks for the help!
