Inetwl
Oct 14, 2022Aspirant
R6400v2 begins to power cycle when the IP address is changed
Hello,
I have an R6400v2 that was to be secondary to another router on my network. When it was attached to the other router, it would begin to power cycle. When its IP address was changed away from 192.168.1.1, it would also power cycle.
Some of the troubleshooting steps that were performed were:
- I purchased a new power supply to ensure that it was compatible with the router.
- I plugged the R6400v2 into the wall instead of a USB or a surge suppressor.
- The router behaved long enough to update the firmware to the most recent edition (R6400v2-V1.0.4.118_10.0.90).
- The R6400v2 was configured to match my home network by connecting a PC to an Ethernet port.
- After the R6400v2 router was configured, it was connected to the Internet via the other router.
- When the other router was 192.168.1.1, the R6400v2 would power cycle, as though it was trying to be 192.168.1.1 unsuccessfully. It did the same thing with a different router when the IP address of the R6400v2 was changed.
Is there documentation that describes how to connect an R6400v2 to another router without touching off the endless power cycle?
1 Reply
Inetwl wrote:
Hello,
While power cycling is odd, having two routers on your network breaks the rules for recommended practice.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate and independent networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
That has its drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But your main router should handle the traffic as required.I would try that and see if the reboot still happens.
