agfazio
Jun 11, 2021Follower
R6400v2 bridge or access point or vlan
I have a peculiar installation question. In our RV we have a wi-fi gateway for controlling the slides, lights, etc. This unit is seperate from any internet connection. I would like to be able to onl...
antinode
Jun 11, 2021Guru
> [...] In our RV we have a wi-fi gateway for controlling the slides,
> lights, etc. [...]
That tells me nothing about what it is, to what it's connected, or
how, or how it's used. Maker? Model number? Any useful information at
all?
> [...] This unit is seperate from any internet connection. [...]
But the R6400v2 has some kind of Internet connection? Any clues on
that?
> [...] The unit in the RV also has a static IP of 192.168.1.1 (can't be
> changed) and needs to see the router at 192.168.1.2. [...]
If you say so, then I'm willing to pretend, but I've never seen a
device whose IP parameters "can't be changed".
> [...] I have setup my AC1750 R6400v2 to be able to do that. [...]
How, exactly?
> [...] how can I connect to the campground wifi signal through the
> R6400v2 at the same time? [...]
What should I already know about your "the campground wifi signal"?
> [...] Would this be setup as an access point, bridge, or vlan? Or some
> other way with other hardware?
I don't know enough about what you're doing with what, or how any of
it connects to anything, to make a guess.
