Northwoods
Apr 30, 2022Aspirant
R6400v2 Can I run this unit as a secondary WIFI to my New EERO 6 wifi
Just added Frontier Internet and it includes an EERO RN Z Pro6 wifi. Some older items in my house don't recognize the wifi. Can I run a secondary Nitehawk out of the ethernet connection and operate ...
Apr 30, 2022Guru - Experienced User
Yes you can.
Just set the R6400 in access point mode to prevent a double nat.
When you setup the wifi bands, just make sure to put the netgear on different channels for both 2.4ghz and 5ghz to prevent interference.
Northwoods
Thank you, I'll try it.
- michaelkenwardMay 01, 2022Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Check the section in the manual Use the Router as a Wireless Access Point (wired to the router) or Set Up the Router in Bridge Mode (with a wifi lino to the router).
You may have done that already. I can't tell from your messages.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
