dougaday
Dec 17, 2021Follower
R6400v2 Can't connect to the router itself
R6400v2 Installed firmware update which caused delays in connecting to websites or wouldn't connect at all. Tried logging onto the router to check the settings but it wouldn't connect to the router. ...
Dec 17, 2021Guru - Experienced User
you tried the default 192.168.1.1?
Whats it connected to for gateway?
Sometimes during setup it'll change its default if you're gateway is a modem/router combo device. Then it usually changes to the 10.0.0.1
