dougaday
Dec 17, 2021Follower
R6400v2 Can't connect to the router itself
R6400v2 Installed firmware update which caused delays in connecting to websites or wouldn't connect at all. Tried logging onto the router to check the settings but it wouldn't connect to the router. ...
DUIdui
Dec 23, 2021Aspirant
Also have this problem after installing firmware V1.0.4.122_10.0.95.
michaelkenward
Dec 24, 2021Guru - Experienced User
Same question for you as the one from plemans .
What is the modem/gateway (if there is one) in front of lour router.
