dougaday
Dec 17, 2021Follower
R6400v2 Can't connect to the router itself
R6400v2 Installed firmware update which caused delays in connecting to websites or wouldn't connect at all. Tried logging onto the router to check the settings but it wouldn't connect to the router. ...
wcalifas
Dec 25, 2021Prodigy
You can always try and applying firmware through the tftp method even if your router isn't bricked. The same method we use to unbrick routers is a way to update the firmware if you're having issues with certain firmwares. Look on youtube "how to debrick a router with tftp."
Tvestra
Dec 27, 2021Star
FYI. I the could not get the tftp method to work, but when the router reset I was able to log on and revert back to .91. I restored my config settings and everything works as it should. I am a little leary of retrying .95 for now. Still do not know why the web server ports were not open when I was running .95. Thank you all for your help and have a good safe new year.
